VPN with router
i'm trying with usg40
wan 192.168.8.2 lan 192.168.9.1 Public ip of router 2.42.21.. .. router 192.168.8.1
if connect my linux pc on 192.168.8.?? VPN ike2 on 192.168.8.2 con preshared-key work regularly.
if i connect the same vpn but on 2.42.21. . .. after NAT of ports 500 e 4500 udp on router
connect temporarly and don't work
other vpn with same USG same router but other client VPN on windows work OK
Hi (ciao) @federicofederigi
afaik also ports 50 an 51 should be natted from your vodafone station to usg.
P.S. suppongo tu abbia buone ragioni per non dirottare tutto il traffico all'usg e gestire le policy di sicurezza su quest'ultimo…
Fred
Ho girato tcp 50 e tcp 51. Ho girato tutte le porte sul USG40 e messo in dmz e disabilitato policy.
ma fa la stessa cosa, sembra connesso ma non funziona, e dopo qualche minuto si scollega
Hi @federicofederigi,
If the USG40 is placed behind the router, you need to create both NAT and firewall rules to allow UDP port 500 and 4500 on that router. On USG40, set 0.0.0.0/0 in the Local Policy of VPN Connection.0 -
do you mean this local policy? (named LINUX_ALL)
with this i have the same problem
this is new log. . . i think another step. . . but connection lose immediately . .
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
