Connectivity Check bug route down when delete the routing rule
Found this nice bug when testing
VPN300 V5.35(ABFC.0)ITS-23WK06-r107740
make a routing rule without Connectivity Check enabled say:
incoming ZyWALL
HTTPS
next hop VLAN443
Then make a rule above that with say
incoming VLAN3000
any
next hop GE4
enable Connectivity Check with Disable policy route automatically while Interface link down checked to a IP that you will fail
Wait for the routing rule to go red then remove it and what happens is the rule that was number 2 goes to numbed 1 and it goes red because its Connectivity Check got enabled because of the routing rule you removed.
Hi @PeterUK ,
Greeting Forum,
We're investigating this issue. I will update the post if any news.
Thank you
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
