Connectivity Check bug route down when delete the routing rule
PeterUK
PeterUK Posts: 4,446 image  Guru Member
edited April 2023 in Security
Found this nice bug when testing
VPN300 V5.35(ABFC.0)ITS-23WK06-r107740
make a routing rule without Connectivity Check enabled say:
incoming ZyWALL
HTTPS
next hop VLAN443
Then make a rule above that with say
incoming VLAN3000
any
next hop GE4
enable Connectivity Check with Disable policy route automatically while Interface link down checked to a IP that you will fail
Wait for the routing rule to go red then remove it and what happens is the rule that was number 2 goes to numbed 1 and it goes red because its Connectivity Check got enabled because of the routing rule you removed.
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 981 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @PeterUK ,
    Greeting Forum,
    We're investigating this issue. I will update the post if any news.
    Thank you
  • Zyxel_Kevin
    Hi @PeterUK ,
    Please find the inbox, I've sent the DF for this issue.
    Thank you
