USG 200 Flex, AP Manual Firmware Update (missing)
Best Answers
check in config
capwap manual-add enable
capwap fw-updating mode manual
capwap ap fallback disable
capwap ap fallback interval 30you could then change it to manual if needed apply config
Some AP have low versions then others
check in config
Thank you Peter for your suggest but why the "Upgrade" button is unavailable (grayed)
i have 3 AP (WAC6103D-I), with firware version 6.28, i'd like to upgrade to latest version (6.55?) but i can't understand how…
- 441 Beta Program
- 209 Nebula Ideas
- 534 USG FLEX H Series
- 338 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
