SecuExtender 4.0.3.0 (windows) not working (VPN connection still ok)
Asgatlat
Asgatlat Posts: 135 image  Ally Member
First Comment Friend Collector Eighth Anniversary
edited April 2021 in Security
hi,
i've tried the new version of Secuextender for windows (4.0.3.0).
the soft success to established the SSL VPN tunnel, but i can't reach the remote network.
the 4.0.2.0 still work
i have a  Zywall 110 with firmware V4.32(AAAA.0)
  • Asgatlat
    ok, i fixed it :
    -uninstall secuextender
    -reboot
    -uninstall all wan card in device manager
    -clean the registry (with ccleaner in eg)
    -reinstall secuextender
«1
  • Asgatlat
    ok, i fixed it :
    -reboot
  • triJRO
    triJRO Posts: 10 image  Freshman Member
    Same Problem here. I'm connected but can't access the remote network. The virtual LAN adapter doesn't receive any data. When i try to reinstall Version 4.0.2. I get the error "Invalid command line"
    and when i try to remove the WAN-Card manually i end up with an error "Client for Microsoft networks could not be removed" 0x80071779.
    Can anyone help me how to get a working System again?
  • techie123
    techie123 Posts: 5 image  Freshman Member
    I had the same issue before and their tech support gave me a patch. I upload it and it still working fine. You can call them and ask for the patch.
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,499 image  Zyxel Employee
    The latest firmware will be sent to you in the private message. Please check your inbox.
  • triJRO
    Thank you Emily,
    the firmware update fixed the issue. I hope the firmware will be released soon officially so less people have to come here to get the fix manually.
    But thanks for the fast support. Very appreciated!
  • TommyD
    TommyD Posts: 1 image  Freshman Member
    Hi, will the update be official?
  • Zyxel_Emily
    edited November 2018
    Hi @TommyD,
    Yes, we confirm that SSL VPN will be working fine in the next official release 4.33. It will be released in late December.
    - SSL VPN tunnel can be established.
    - After SSL VPN tunnel is established, ping USG’s LAN subnet successfully.
  • ClearComIT
    ClearComIT Posts: 2 image  Freshman Member
    @Zyxel_Emily Hello there! We are experiencing the same issue with a USG 110 running 4.32(AAPH.0) firmware. Can you please send the firmware via DM as well? Thank you
  • Thysmith
    Thysmith Posts: 16 image  Freshman Member
    Hi I have several devices that are working with local accounts but AD accounts are failing to connect to the SSL VPN. USG 40 and 20's.
  • Zyxel_Emily
    The latest firmware is sent to you in the private message.
