USG FLEX 200 - Can't access Lan network from conexion VPN SSL
Hello everyone,
We set up a VPN SLL on a USG FLEX 200, we can connect to it with Zyxel SecuExtender, and when we check our IP from the mobile device we get the good IP from VPN IP pool.
But we cannot ping or reach anything in the Lan of the Firewall.
We checked the Firewall policy control and the VPN setup but couldn't find any reason why. Could it be an other option to setup ?
Thanks for any suggestions.
Hi @ChampagneDesk ,
Greeting Forum, please kindly check :
1)You have check "Force all traffic to enter SSL VPN tunnel", if not please check if your LAN subnet is i n 'Selected Address Objects"
2)Please kindly check there is no overlap address in the laptop/PC. For example, firewall's LAN have 192.168.68.0/24 . laptop/PC should not have.
If the issue still, please kindly share your config file and screenshot of cmd output "route print" by private message.
Thank you
- 220 Nebula Ideas
- 603 USG FLEX H Series
- 482 News and Release
