USG 200 Flex, AP Manual Firmware Update (missing)
Skylink
Skylink Posts: 32  Freshman Member
First Comment Friend Collector Seventh Anniversary
how can i manually update the access points firmware since the menu is gone?
USG 200 Flex, Firewall firmware v.5.36
Best Answers
    PeterUK Posts: 3,893  Guru Member
    check in config
    capwap manual-add enable
    capwap fw-updating mode manual
    capwap ap fallback disable
    capwap ap fallback interval 30
    you could then change it to manual if needed apply config
  • Skylink
    Thank you Peter for your suggest but why the "Upgrade" button is unavailable (grayed)
    i have 3 AP (WAC6103D-I), with firware version 6.28, i'd like to upgrade to latest version (6.55?) but i can't understand how…
