I need to assign public access to my "Chat Server"
Jeff_ATS
Jeff_ATS Posts: 11 image  Freshman Member
edited April 2023 in Security
I have setup Services, a Service_Group and an Object as follows:
I want to setup pulic access from my WAN port to the Chat_Server
I setup NAT as I think understand it:
  • mMontana
    mMontana Posts: 1,473 image  Guru Member
    AFAIK is almost correct. Neverthless, I'd use some different parameters.
    Considering how did you grouped services, Virtual Server is close to correct to me.
    Also, if your WAN interface is configured with the "User-defined External IP" I'd choose in "external IP" (instead of "User Defined" ) "WAN1_Interface_Host" or… the actual interface that connect to internet and which should be the path to access to your Chat Server.
