Is there a way to see the firmware version of all my ATP units on one screen?
ChipConnJohn
ChipConnJohn Posts: 45 image  Freshman Member
Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula First Comment Fifth Anniversary
Hi All,
I can't seem to find a screen in all the various Zyxel portals that will tell me the firmware version of all my devices. In My Devices, I can click into each one individually, but I'd like to be able to do a quick visual scan. Is there a screen or a report I'm missing? I don't use Nebula, btw.
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @ChipConnJohn
    Thanks for your inquiry and suggestion. Currently, we haven't supported this feature on myZyxel. But, as you mentioned, the user can navigate to myZyxel > Device Management > My Devices to check the firmware version respectively.
    Click the device you want to check.
    Check its firmware version.
    Thanks.
