VPN routing
Ajay
Ajay Posts: 5 image  Freshman Member
Hi Team,
How do l ensure all my route users can browse around my server successfully, they can connect but not see the server which is on ip address 192.168.16.2 . l have a USG60
  • Zyxel_James
    Zyxel_James Posts: 809 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    If it's your scenario
    USG60_A:
    LAN1: 192.168.11.0/24
    Local Policy 192.168.11.0/24
    Remote Policy 192.168.12.0/24
    USG_B
    LAN1 192.168.12.0/24
    LAN2 192.168.16.0/24 (server is 192.168.16.2)
    Local Policy 192.168.12.0/24
    Remote Policy 192.168.11.0/24
    Please add policy route for routing the traffic to the server
    For USG60_A:
    Add a policy route
    source address: 192.168.11.0/24
    destination address: 192.168.16.2
    next-hop: VPN tunnel
    For USG60_B
    Add a policy route
    source address: 192.168.16.2
    destination address: 192.168.1.11/24
  • Zyxel_James
    edited April 2023
    Hello @Ajay,
    Could you provide your topology of the network?
    Is 192.168.16.2 in the local policy of your VPN tunnel?
    You can enable the log option for the policy rules and check if there is any blocked log when the users connect to the server.
    James
  • Ajay
    Good Morning James,
    Thanks for the advice, l have not adjusted the policy control, if l have am not sure how l did it. how do l enable the log to capture this
  • Zyxel_James
    USG60_A:
    USG_B
    For USG60_A:
    Add a policy route
    For USG60_B
    Add a policy route
