ISP account l2tp don't stay Nailed-Up when disconnected bug
2»
    PeterUK Posts: 4,427 image  Guru Member
    edited May 2023
    The Cisco MAC IS my ISP WAN gateway the other MAC is one I set in Zywall
    The captured IS from FLEX
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 981 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @PeterUK ,
    I also overwrite my WAN MAC address, but still can't see issue.
    I didn't even turn on conn-check.
    Could you provide your config by private message ? Thank you
    edited May 2023
    Like I say this happened with privatevpn.com server so their server are the reason testing with what ever server your using will not cause the same result I was seeing.
    You have the packet capture to replay packets.
    I have since moved on from privatevpn.com to test another VPN service.
    For example I'm now test at www.hideipvpn.com and their L2TP connection is fine so likely its how privatevpn.com server are that cause a problem with the USG reconnect.
    Not sure who contact but the edit button don't seem to work on this site any more
