dhcp offer zyxel xgs-4526
cesar
cesar Posts: 4
greetings
after creating a vlan, enabling a trunk port and enabling dhcp service on a zyxel xgs-4526 switch and establishing the connection with a gs1910 switch via the trunk, the pc connected to a port in access mode on the switch gs1910 not receiving dhcp offer
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,814  Guru Member
    Hi @cesar,
    Since you have created VLAN on Zyxel xgs-4526, you cannot use the VLAN trunk on it. The VLAN trunk only forwards unknown VLAN packets. Please set up the VLAN configuration correctly.
    Zyxel Melen
  • cesar
    cesar Posts: 4
    Hi Zyxel_Melen ,
    The Zyxel xgs-4526 switch is working as a core where all the vlans to be used in the
    network were created, and for this reason the trunk is carried out between the two computers so that they establish communication and thus be able to distribute the dhcp of the floor vlan that corresponds
  • Zyxel_Melen
    Hi @cesar,
    Could you share your topology and current configuration with me? I can confirm what could go wrong.
    Zyxel Melen
  • cesar
    cesar Posts: 4
    HI @Zyxel_Melen
    Here I send you the topology, the laptop does not receive the DHCP offer
    although the MAC of the laptop is seen in the SW gs1910 and also in the SW CORE XGS4526.
  • Zyxel_Melen
    Hi @cesar,
    Thanks for the topology. However, I still need to check the configuration of GS1910 and XGS4526. Could you send the configuration to me via private message? Many thanks.
    Zyxel Melen
