DAI allows other source IP on DHCP MAC
13»
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,615 image  Zyxel Employee
    Hi @PeterUK,
    The static binding priority is higher than DHCP snooping on the Zyxel switch.
    This means MAC 1 binds in the static table will always work. And there won't be an IP+MAC binding learned from DHCP snooping.
    So, you can be assured of using our IP source guard function.
    Zyxel Melen
