ATP100 - Signature date "Threat Intelligence Machine Learning" out of date
e_mano_e
e_mano_e Posts: 114 image  Ally Member
First Answer First Comment Friend Collector Fifth Anniversary
I just updated the ATP100 to the latest firmware V5.36.
After that I manually updated the signatures of all services.
Now the "Threat Intelligence Machine Learning" service says "2017-12-11" as release date!?!
Is this intended or is this a bug in the latest firmware?
Thanks.
«1
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,539 image  Guru Member
    edited April 2023
    Hi @e_mano_e ,
    Thanks for issue report.
    We have addressed the issue and will keep you updated stauts in this post.
  • itxnc
    itxnc Posts: 102 image  Ally Member
    First Comment Friend Collector Seventh Anniversary
    We're seeing the same thing on ATP and Flex w/Gold
  • PhilippeBkk
    PhilippeBkk Posts: 13 image  Freshman Member
    Same for us. There are issue with Malware false positive detection. Zyxel ask to update signature but Threat Intelligence Machine Learning (TIML) remain from 2017
    2017-12-11 12:46:40 (UTC+07:00
  • e_mano_e
    «but Threat Intelligence Machine Learning (TIML) remain from 2017
    2017-12-11 12:46:40 (UTC+07:00»
    This is a bug in the latest official firmware V5.36.
  • QuiteSmart
    QuiteSmart Posts: 67 image  Ally Member
    Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - WLAN
    hello with 5.35 the first manual attempt to update machine learning resulted in an error (but updates antimalware), trying again with antimalware up to date it works for TIML as well. current signature is 1.0.0.20230516.0
    2023-05-16 11:15:08 (UTC+01:00)
    hope this helps
  • Zyxel_Cooldia
    The issue will be merged into next firmware, will update firmware schedule in this thread.
  • aait
    aait Posts: 14 image  Freshman Member
    After the firmware update 5.36 Patch 2 all my ATP100 and ATP200 are again with TIML 1.0.0.20171211.1 When will this situation be fixed definitively? With every firmware update, it comes back
  • jonatan
    jonatan Posts: 199 image  Master Member
    5 Answers First Comment Friend Collector Eighth Anniversary
    edited May 2023
    @aait
    Install the weekly firmware.
    My ATP 200 has V5.36 installed(ABFW.1)ITS-23WK21-r109592, there are no problems with signatures.
  • aait
    @jonatan
    I have installed ZLD4.73 & ZLD5.36 patch 2 on all firewalls I manage from USG210/310 to ATP500, I cannot install 23WK21 which is vulnerable to CVE-2023-33009 and CVE-2023-33010
