NWA220AX-6E vs WAX620D-6E difference ?
Thanks for the quick reply.That explains that various online shops listed both APs with the same tec specs. The different antenna configuration is a bit of specific.
The difference between NWA220AX-6E vs WAX620D-6E is antenna type.
NWA220AX-6E with 4x4 + 2x2 MIMO embedded antenna. Ceiling-mount patterns for NWA220AX-6E.
WAX620D-6E with 4x4 + 2x2 dual-optimized antenna. Ceiling-mount and Wall-mount patterns for WAX620D-6E.
Ceiling-mount Wall-mount
In case using WAX620D-6E, you can choose Antenna setting as Ceiling or Wall.
On Nebula, go to Access point > Configure >Radio setting > Click AP
On Standalone, go to Maintenance > Antenna > Antenna Switch
Zyxel_Judy
Hi @tremor,
In addition, there are differences between Operating mode and Conducted typical transmit output power.
1. Operating mode:NWA220AX-6E: Nebula Cloud managed/ standalone
WAX620D-6E: Nebula Cloud managed/controller-managed/standalone
2. At 5GHz, the output power of WAX620D-6E is bigger than NWA220AX-6E 3dBm.
To get the full spec, please refer to these datasheets:
Zyxel_Judy
I was just looking for this same info to this question. Glad to see it already posted. thanks.
The website says the NWA220AX-6E is a dual optimized antenna.
- 441 Beta Program
- 294 Service & License
- 461 News and Release
