Zywall 110 to ATP200 converter
PlusAuto
PlusAuto Posts: 7 image  Freshman Member
edited May 2023 in Security
I`m in need to convert a config from a Zywall110 to ATP200. I cannot do this with the online converter tool.
Is there a way to do this easily ?
Kind regards,
Michel
  • Zyxel_James
    Zyxel_James Posts: 809 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Hello @PlusAuto, the converted ATP200 configuration is sent through our PM, please check, thank you.
    PeterUK Posts: 4,411 image  Guru Member
    You can do it manually but it takes skill you have to be mindful of the interferers from one to the other.
    ….the other thing is passwords might not be copied over…
  • mMontana
    mMontana Posts: 1,461 image  Guru Member
    https://community.zyxel.com/en/discussion/16514/usg-flex-100-w-built-in-ap-not-comply-with-the-config
    https://community.zyxel.com/en/discussion/13622/usg60w-to-usg-flex-100w-configuration-conversion
    Please, read my experience before considering viable the conversion of the configuration…
  • Zyxel_James
    Yes, ZyWall 110 is only able to converter to USG FLEX 500 or VPN100 on our Online converter.
    You can provide your config to me through PM, I will do it for you.
    James
  • Zyxel_James
  • Chris_b4s
    Chris_b4s Posts: 2 image  Freshman Member
    i have the same problem. need to convert from Zywall110 to ATP200.
    Can you help me please?
    Thank you.
  • chrisgrass
    chrisgrass Posts: 2 image  Freshman Member
    Hey,
    can you also convert my Zywall110 config to an ATP200 config please?
    Thank you.
