Zywall 110 to ATP200 converter
Hello @PlusAuto, the converted ATP200 configuration is sent through our PM, please check, thank you.
You can do it manually but it takes skill you have to be mindful of the interferers from one to the other.
….the other thing is passwords might not be copied over…
https://community.zyxel.com/en/discussion/16514/usg-flex-100-w-built-in-ap-not-comply-with-the-config
https://community.zyxel.com/en/discussion/13622/usg60w-to-usg-flex-100w-configuration-conversionPlease, read my experience before considering viable the conversion of the configuration…
Yes, ZyWall 110 is only able to converter to USG FLEX 500 or VPN100 on our Online converter.
You can provide your config to me through PM, I will do it for you.James
i have the same problem. need to convert from Zywall110 to ATP200.
Can you help me please?
Thank you.
Hey,
can you also convert my Zywall110 config to an ATP200 config please?
Thank you.
- 3K Nebula
- 229 Nebula Ideas
- 130 Nebula Status and Incidents
- 6.6K Security
- 661 USG FLEX H Series
- 359 Security Ideas
- 86 Switch Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 305 Service & License
- 497 News and Release
- 95 Security Advisories
- 5K FAQ
- 89 About Community
- 110 Security Highlight
