Broadcast (storm) Problem WAC5302D-S
Hello guys,
were using an NXC5500 with multiple Zyxel APs in an enterprise enviroment. Only the WAC5302DS APs get stuck random. The only maybe problematic thing i can diagnostic is that on any WACs RX side are big Values of broadcast pakets while all the other non WAC aps are stable and have very low BC rates. How could this be in a single VLAN ??? i got no idea
Hi @Bonesai
Could you help to confirm the CPU status of the WAC5302D-S when the issue occurs?
As you said, the WAC5302D-S will get stuck, does it mean it will provide wifi service but the stations cannot surf the internet?
Is it possible to collect the packet and realize what kind of the broadcast packet? It might occupy the performance of the AP.
Thanks.
Joslyn5
Hi @Bonesai
Thanks.
Joslyn5 -
-Maybe just tell me what i should do could also provide LOGs etc.
-Yes, its providing WiFi Service but the WiFi clients cant access any networks service anymore ( internet, servers even a ping want work), THE AP is reachable from Ethernet Side, reboot or replug is solving the problem for some time. I try some paket monitoring to find out more about the packet type.
Its not location depending but definitely AP Type based. I unplug the WAC and Connect an NWA - problem is gone ! I attached an Info screen for example, 1st picure is NWA5301NJ Bcast, 2nd WAC0 -
Hi @Bonesai
I have sent you a DF of NXC5500 via private message since we met a similar issue before. Please help to upgrade it and let me know if it resolves your problem. If not, please collect the diagnostic of the AP and provide us to analyze.
Thanks.
Joslyn0 -
Hi Joslyn
The FW didnt solve the Problem. I will now look to collect and provide the APs diag file.
best regards0
- 434 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 116 Nebula Status and Incidents
- 6K Security
- 391 USG FLEX H Series
- 295 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 4K FAQ
- 83 Security Highlight
