Buying a Zyxel USG-100 from second hand marketplace
AdmiralOOM
AdmiralOOM Posts: 5 image  Freshman Member
I am planning on purchasing your product from a second hand marketplace, but I want to completely reset it and load in every file from scratch.
It is a ZyWall USG 100.
Is there an easy way to perform this complete reset, and to make sure that no bad config files are left on the system.
    PeterUK Posts: 4,511 image  Guru Member
    edited May 2023
    The USG100 is old and no longer updated and speed might not be that good…
    But a reset button will use default settings.
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 988 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @AdmiralOOM ,
    Greeting Form and thanks @PeterUK ,
    Since the USG100 is very old, we would suggest you to buy a new one for peformance or security concerns.
    Thank you
  • StefanZ
    StefanZ Posts: 203 image  Master Member
    First Comment First Answer Friend Collector Third Anniversary
    I got an USG20 for a very simple site-2-site connection where I need to manage some kiosks every 30 days.
    It refuses all connections, but the three kiosks – and opens the VPN by itself from the LAN towards my FLEX50 at home.
    It ain't too fast, but it sure works well.
