Zywall/USG Series - v3.30P9 (WK48) firmware released!
Zyxel_Charlie
The Zywall/ USG Model firmware release.
Note: All models support TLS 1.2
protocol.
Firmware version: v3.30P9 (WK48)
Device Model
USG 100-PLUS 330 AACV Download
USG 300 3.30 AQE Download
USG 100 3.30 AQQ Download
USG 200 3.30 AQU Download
USG 1000 3.30 AQV Download
USG 2000 3.30 AQW Download
USG 20 3.30 BDQ Download
USG 20W 3.30 BDR Download
USG 50 3.30 BDS Download
How can I solve update trouble with tis firmware? First I update my USG100-plus via web, and then I've get bootloop. Next i try to restore it througt console/ftp, but I've get this:
Building ...[Update Filesystem]Updating Code//rw/compress.img bad CRC d05c62e9 (should be d6eda5d8)(may instead be incorrect password) |/rw/compress.img bad CRC d05c62e9 (should be d6eda5d8)(may instead be incorrect password) -/rw/compress.img bad CRC d05c62e9 (should be d6eda5d8)(may instead be incorrect password) //rw/compress.img bad CRC d05c62e9 (should be d6eda5d8)(may instead be incorrect password) -/rw/compress.img bad CRC d05c62e9 (should be d6eda5d8)(may instead be incorrect password) //rw/compress.img bad CRC d05c62e9 (should be d6eda5d8)(may instead be incorrect password) |/rw/compress.img bad CRC d05c62e9 (should be d6eda5d8)(may instead be incorrect password) -/rw/compress.img bad CRC d05c62e9 (should be d6eda5d8)(may instead be incorrect password) //rw/compress.img bad CRC d05c62e9 (should be d6eda5d8)(may instead be incorrect password) -^|0 -
Anything for the NBG6716 or EMG2926 after V1.00(AAQT.6)b3?
There is an issue with USG100-plus firmware attached here. Tried many times and everytime it fails. Had to recover the old firmware. Keep getting "/rw/compress.img bad CRC" error.
anyone got solution?
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 499 USG FLEX H Series
- 323 Security Ideas
- 49 Wireless Ideas
- 287 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
