Buying a Zyxel USG-100 from second hand marketplace
I am planning on purchasing your product from a second hand marketplace, but I want to completely reset it and load in every file from scratch.
It is a ZyWall USG 100.
Is there an easy way to perform this complete reset, and to make sure that no bad config files are left on the system.
The USG100 is old and no longer updated and speed might not be that good…
But a reset button will use default settings.
Hi @AdmiralOOM ,
Greeting Form and thanks @PeterUK ,
Since the USG100 is very old, we would suggest you to buy a new one for peformance or security concerns.
Thank you
I got an USG20 for a very simple site-2-site connection where I need to manage some kiosks every 30 days.
It refuses all connections, but the three kiosks – and opens the VPN by itself from the LAN towards my FLEX50 at home.
It ain't too fast, but it sure works well.
- 602 USG FLEX H Series
- 480 News and Release
