VPN Primer needed for my USG 100 Flex
2»
  • tesagig
    tesagig Posts: 60  Ally Member
    IKE SA [] is disconnected
    73.73.116.92:500
    98.46.107.197:10228
    IKE_LOG
    5
    2023-05-12 14:34:13
    info
    IKE
    [SA] : No proposal chosen
    73.73.116.92:500
    98.46.107.197:10228
    IKE_LOG
    6
    2023-05-12 14:34:13
    info
    IKE
    [SA] : Tunnel [WIZ_VPN_v2] Phase 1 proposal mismatch
    IKE_LOG
    7
    2023-05-12 14:34:13
    info
    IKE
    The cookie pair is : 53192 [count=3]
    98.46.107.197:10228
    IKE_LOG
    8
    2023-05-12 14:34:13
    info
    IKE
    Recv
    IKE sa: SA([0] protocol = IKE (1), AES CBC key len = 256, HMAC-SHA256
    PRF, HMAC-SHA256-128, 2048 bit MODP; [1] protocol = IKE (1), AES CBC key
    len = 256, HMAC-SHA256 PRF, HMAC-SHA256-128, 256 bit ECP; [2] protocol =
    73.73.116.92:500
    IKE_LOG
    9
    2023-05-12 14:34:13
    info
    IKE
    [INIT] Recv: [SA][KE][NONCE][NOTIFY][NOTIFY][NOTIFY][NOTIFY]
    73.73.116.92:500
    IKE_LOG
    10
    2023-05-12 14:34:13
    info
    IKE
    Receiving IKEv2 request
    Thank you for the continued help. I am still getting some sort of mismatch
    PeterUK Posts: 3,983  Guru Member
    Try add in for Phase 1 and 2 Settings
    AES256 SHA256
    The order might matter
  • tesagig
    still no luck…
    still Phase 1 proposal mismatch?
    Try changing the key group and reboot ipad set the client with ikev2 in IPsec identifier
    Setup a DDNS with like no-ip and in advance for local ID Type DNS and content your DDNS
    That should be everything
  • tesagig
    edited May 2023
    not sure in phase 1 or two. I tried on a second ipad
    BTW. there is a "connect" menu item in VPN connection tab. Not knowing what I am doing, I hit connect with the following error.
    CLI Number: 0
    Error Number: -16015
    Error Message: 'Dial a dynamic tunnel has failed for Crypto map.'
    Here is the log
    2023-05-14 16:51:21
    info
    IKE
    IKE SA [WIZ_VPN_v2] is disconnected
    server:4500
    client:4500
    IKE_LOG
    12
    2023-05-14 16:51:21
    info
    IKE
    The cookie pair is : 0x8875ff66f1736b17 / 0x5989436118077d7c
    Server:4500
    client1:4500
    IKE_LOG
    13
    2023-05-14 16:51:21
    info
    IKE
    [AUTH] Recv:[IDi][NOTIFY][IDr][CONF][NOTIFY][NOTIFY][SA][TSi][TSr][NOTIFY]
    client1:4500
    Server:4500
    IKE_LOG
    14
    2023-05-14 16:51:21
    info
    IKE
    The cookie pair is : 0x5989436118077d7c / 0x8875ff66f1736b17
    client:4500
    Server:4500
    IKE_LOG
    15
    2023-05-14 16:51:20
    info
    IKE
    [INIT] Send:[SAr1][KE][NONCE][NOTIFY][NOTIFY][NOTIFY][CERTREQ][VID][VID][VID][VID][VID][VID]
    Server:500
    client:41912
    IKE_LOG
    16
    2023-05-14 16:51:20
    info
    IKE
    Server:500
    client:41912
    IKE_LOG
    17
    2023-05-14 16:51:20
    info
    IKE
    Recv IKE sa: SA([0] protocol = IKE (1), AES CBC key len = 256, HMAC-SHA256 PRF, HMAC-SHA256-128, 2048 bit MODP; [1] protocol = IKE (1), AES CBC key len = 256, HMAC-SHA256 PRF, HMAC-SHA256-128, 256 bit ECP; [2] protocol = IKE (1), AES CBC key len = 256, HM
    client:41912
    Server:500
    IKE_LOG
    18
    2023-05-14 16:51:20
    info
    IKE
    client:41912
    Server:500
    IKE_LOG
    19
    2023-05-14 16:51:20
    info
    IKE
    client:41912
    Server:500
    IKE_LOG
    20
    2023-05-14 16:51:20
    info
    IKE
    The cookie pair is : 0x5989436118077d7c / 0x8875ff66f1736b17 [count=2]
    client:41912
    Server:500
    IKE_LOG
