USG20-VPN Unable to log in after upgrading the firmware
My device is usg20-vpn
The original version was 4.16. To update to the latest version 5.36.
I directly download the bin file of 536ABAQ1C0 from the official website
Upload to the device
But after the update, I can't log in with my account password.
I can't get in even if I use the default account admin password 1234
I wonder if any of you have encountered the same problem?
Can you give me some answers or suggestions, thanks
1: try to flush the cache of your browser
2: try to login using the "incognito" mode of your favourite browser
3: try to login using another browser
4: try to write down your password on notepad/something similar before inputting that on the password field of your deviceQuestion: does your password have any special character(s)? Would you please share which eventually is?
My password is 1234 so no special characters
In the end, I restored the version back to the original version, and then threw back the backup config, so it was restored to the original state
The main reason is that I don’t know if I can upgrade the version directly, or there must be an upgrade path0 -
Hi @rv3452 ,
Can you send me your configuration in PM for further checking. Thanks
Thanks everyone, I have solved my problem
Hi @rv3452 ,
Could you share how to solve this problem with the community users😀
- 588 USG FLEX H Series
- 477 News and Release
