SecuReporter after Trial Reset
And, as our reseller told me, the price for licenses will be public in November 2018. Why you give us the link to buy, when at the moment there is no chance?
The other point is, that we want see the whole traffice, when possible. We tried to do this like the way someone describe in another post, but in UTM Profil => AppPatrol I have no box to activate "all traffic". Is there a chance for us?
Thanks in advance
Celestis
This is acculy a really good question.I'm struggling with the same issues!0
Hi @Celestis,
To use SecuReporter, the USG60 must run with firmware 4.32(AAKY.0).
After the device is registered to myZyxel.com, login to myZyxel.com and go to Device Management > My Device > USG60.
Click “Details” and “Activate” to activate SecuReporter trial service.
After SecuReporter trial service is activated, you'll find SecuReporter in CONFIGURATION > Cloud CNM.
Then you can enable “Enable SecuReporter” and “Include Traffic Log”.
Hi @Celestis,
The buy link for SecuReporter cannot be grayed out on myZyxel.com.
The link and the standard license will be available in November.
You can still enjoy 30 days free SecuReporter trial by activating trial service at myZyxel.com.
Tech support just told me secureporter for the USG series not ready til Jan 2019 with new firmware 4.33.0
Hi @iSpeed,USG series support SecuReporter since firmware 4.32.After the device is upgraded to 4.32 and registered to myZyxel.com, you can activate SecuReporter trial service at myZyxel.com to start using it.1
As far as I know, most of USG models support SecuReporter since firmware 4.32, the only exceptional models are USG310/1100/1900 that will be supported in firmware 4.330
Unfortunately I had to roll all my usg40w's back to the patch version 4.31 to fix the local access points going offline after 2 or 3 days bug.0
Hi @iSpeed,
About the Local-AP going offline issue, the bug will be merged to the next official firmware 4.33.
It will be released in late December.
Sorry to make you downgrade USG40W to fix offline radio issue but not able to use SecuReporter.
If you need firmware 4.32 with offline radio issue in order to use SecuReporter, here are the firmware for your verification before 4.33 is officially released.
USG20W-VPN
https://www.dropbox.com/s/gxgtlys7tyfuikf/432ABAR0ITS-WK43-r86079.zip?dl=0
USG40W
https://www.dropbox.com/s/cwsujmservu6xo1/432AALB0ITS-WK43-r86079.zip?dl=0
USG60W
https://www.dropbox.com/s/qipt17modzgj11p/432AAKZ0ITS-WK43-r86079.zip?dl=0
What happen after secureporter license expired? Can we access to Organization and device?
How about the logs on cloud?0
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.2K Security
- 93 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 921 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 938 Nebula FAQ
- 425 Security FAQ
- 238 Switch FAQ
- 210 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
