ZYXEL DX3200-B0 Turk Telecom
Hello, I have a ZyXEL DX-3200 B0 router that my internet service provider provided. There are blind spots in my house where wi-fi signals can't reach. I want to buy an access point with mesh system that is suitable for the modem I have. What do you recommend?
HI @kaya ,
You can set any Zyxel access point via ethernet cable to extend the wireless range from DX-3200 B0 router. The clients can roam between DX-3200 B0 and Access point (AP) in case:
- The same SSID and security method
- 15% to 20% overlapping coverage for 2 devices
If you mentioned about Mesh as the wireless connection mechanism to AP connects to router, it doesn’t work between AP and EX3300 router. Zyxel APs uses the Mesh to connect to Zyxel APs only.
Zyxel_Judy
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
