Zone cellular base port PPP bug
PeterUK
PeterUK Posts: 4,411 image  Guru Member
edited May 2023 in Security
Ok really odd one
VPN300 V5.36(ABFC.1)
I have a USB Huawei E303 its IP is 192.168.8.100 I make zone cellular1
On ge4 I have a Nighthawk M2 Mobile Router set to DHCP gets a 10. IP with its zone being cellular1.
I have hideipvpn with PPP setup for L2TP base port ge4 (interesting you can't use a USB cellular) zone test
I have a routing rule LAN1 on ge3 for client 192.168.255.193 to use hideipvpn ping 1.1.1.1
What happens is the PPP looks to connect...in a odd way where it uses the USB cellular not out ge4 pings go out ge4 as 192.168.8.100 not 10.
When I disable USB or set cellular zone to none then PPP works.
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,461 image  Zyxel Employee
    Hi @PeterUK
    Could you send the remote access of this VPN300 to check the symptom in the private message? Thanks!
