Windows 10+ IKEv2 VPN with certificate and Peer-ID-Type
Our FLEX200 VPN works like a charm with the native OSX client.
Now I am trying to connect a Win10 machine to the same gateway.
Gateway is IKEv2 with certificate, with Peer-ID-Type set to "E-mail" and Content is set to a made up E-mail address.
Extended Authentication Protocol is set to Server Mode and the desired user group .
I downloaded the certificate, imported it in the Windows Wizard for all users (Local Computer), all good.
Setting up the native VPN client gives me a problem tho: Where do i input the Peer-ID-Type & Content? I assume that the user/pass fields are refering to the Extended Authentication Protocol?
Hi @StefanZ , as far as I know, we cannot adjust the Peer-ID for Windows native VPN, please select Any as the peer ID type
Thanks for clarifying!
I ended up using the ConfigWizard to generate the native Windows .bat & .crt files and that works.
I really hope you enable the Wizard for EXISTING connections soon!
Every time you use it, it will mess with your connections, creates new Objects, instead of offering existing ones, etc..
A wizard is great for something as complex as VPN – but it should not mess with the finely tuned results of days of work every time you require its' assistance.
days of work every time you require its' assistance.You can always create a VPN connection manually. That way it won't mess with your existing config.
Yes, but I also have to do it all manually. EVERY time. And then create/deploy .mobileconfig and .bat files.
- 441 Beta Program
- 293 Service & License
