Static routes can´t access to internet
Is the USG1100 natting the traffic to internet?
Do the servers ping to USG1100?
I think more information is needed to solve the issue.0 -
Yes, the 1100 is natting, the serves with ip in the same lan of the zyxel can access the internet, the servers in different lan can not, I did the routes but dont work.
What information you need.?
NOTE
I have this problem with the 310 with firmware 4.31, but with firmware 4.25 everithing works.0 -
I disable all the snat rules for test, and nat rules with same reaults.0
Hi @ewing,
"I have this problem with the 310 with firmware 4.31, but with firmware 4.25 everything works."
Do you have the backup configuration file with firmware 4.25 version?
We need the configuration file to check the root cause, so I will send you what information we need in the private message.
Hi @ewing,
I follow your topology and set up a router to run the test.
Router: NBG-419N v2
NAT is disabled on the router.
Topology
ISP----(ge1: 10.214.48.25)USG310(lan: 192.168.99.4)----(wan: 192.168.99.5)Router(lan: 172.16.0.1)----PC(172.16.0.2)
Apply config_usg_1100_v4.31_AAPK1.conf to USG310.
USG310 is running with firmware 4.31(AAPJ.0).
In the configuration file, the next hop of static route is modified because the router gets IP 192.168.99.5.
Change the IP of ge1.
Other settings remain the same as yours.
PC(172.16.0.2) ping 8.8.8.8 and 192.168.99.4 successfully.
There is no problem with the static route with firmware 4.31(AAPJ.0) and 4.25.
If PC is still unable to ping 8.8.8.8, we need further information such as remote access to find out the root cause.
After doing so many test, finally I found the solution, I assigned first the public IPs to the interface, removed it, then made the rule 1:1 nat and its working .What happend if I got 100 ips? this time was only 3.0
- 588 USG FLEX H Series
- 477 News and Release
https://youtu.be/o1LSem_6g5w
