Syslog / CEF format
I am wondering why all logs I send to my Graylog server are prepended with the facility ID.
This breaks the auto-parsing on CEF / syslog messages and one must instead handle a RAW input with custom filters.
Example Log:
<142>May 17 13:14:28 usgflex200 CEF:0|ZyXEL|USG FLEX 200|5.36(ABUI.1)|0|IKE|4|devID=aaaaaabbbbbb src=xxx.xxx.xxx.xxx dst=xxx.xxx.xxx.xxx spt=500 dpt=500 dvchost=usgflex200 msg=The cookie pair is : 0xfd348ce9397121212 / 0x75e6d538831121212 cat=IKE ZYlevel=info ZYnote=IKE_LOG
The <142> seems to be the Facility Code "Local 1".
BUT WHY is it prepended to the real message? If I remember correctly, the NWA50AX AccessPoints exhibit the same behaviour.
Since I expect others to have the same problem:
Has anyone here built any GROK extractors for Zyxel Logs? Preferably CEF format, because the pure "Syslog" setting seems to give less details.
It's about the syslog message header.
The first 5 bits 10001 maps to facility Local 1
The last 3 bits 110 maps to level INFO
Raw data binary 10001110 to decimal is 142.
Is the prepended number in syslog also can be seen in other brand device ?
Ah, great info! Thank you!
OK, so generally the leading facility / level info allow it easy to sort the messages for logging servers with little effort – but break native CEF parsing. At least I found nothing to support that this is part of the official format.
- 222 Nebula Ideas
- 616 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
