Problems accessing website on SCR50AXE
Klaus_S_K
Klaus_S_K Posts: 10 image  Freshman Member
Hi again
Trying to access skechers.dk with the Ransomware / Malware Prevention enabled
but the site is blocked. Tried these settings to whitelist the site, but without result. Anyone who can help?
  • Zyxel_James
    Zyxel_James Posts: 809 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Hello @Klaus_S_K
    please add it to the Exception list instead of the allowed domain, thanks.
  • Zyxel_James
    Hello @Klaus_S_K
    I found that skechers.dk is using the IP address 23.227.38.65 and it's categorized as a suspicious or malicious IP
    Please try to add the IP address instead of the domain name to the allowed list.
    Anyway, I will check if it's a false positive as well, thank you.
  • Zyxel_James
    Hello @Klaus_S_K
    Just to let you know, I check the IP address by VirusTotal and it still has security concerns.
    https://www.virustotal.com/gui/ip-address/23.227.38.65
  • Klaus_S_K
    Added the ip and adress to the whitelist, but i still cant access the. On the bright side, my wife wont spend money on shoes ;)
  • Zyxel_James
    Hello @Klaus_S_K
