update firmware failed
i have a situation like in the attached picture, i can't update the firmware of the standby partition. I tried both cloud and local solution.
I found this solution in the forum
https://community.zyxel.com/en/discussion/13011/recovery-steps-for-usg-flex-atp-series-with-device-has-firmware-update-fail/p1?new=1
but the FW present on my device does not match
Hi @DGTinfo
I recommend taking a backup of your configuration. Additionally, try rebooting your device using the #1 partition (or enter following CLI command before rebooting device):
> set firmware boot number 1
Afterward, you can proceed with upgrading your device to the ZLD 5.36 Patch 2 firmware.
backup config download USG20-VPN 4.16 and update standby firmware
https://www.dropbox.com/s/hz53xvjat7llten/USG20-VPN_Firmware_4.16%28ABAQ.1%29C0.zip?dl=1
it might be best to unplug WAN and reboot
from the 2 link i found the firmware 4.16 for the NON wireless version.
However I launch update locally, the file is loaded, then the update is not performed0 -
edited the above for right link to USG20-VPN - ABAQ
They are all listed here
if you have usg20W-vpn you need usg20W-vpn
https://www.dropbox.com/s/ai66w7wqvo5df4j/USG20W-VPN_Firmware_4.16%28ABAR.1%29C0.zip?dl=1
downloaded the correct FW, I tried to update both from the web interface with a local path and via FTP, but it doesn't work.
I also tried the procedure via USB, but in the SSH connection it returns me this error0 -
Hi @DGTinfo
Hi Stanley,
thanks for the advice
At the moment I solved it like this:
configuration backup
booting the device from the outdated partition 1
upgraded partition 2
rebooting the device from partition 2
configuration restore
partition 1 upgradeNOTE
the problem is that by restarting the device from partition 1 the credentials are not updated, luckily I was able to recover the password for this device0
- 237 Nebula Ideas
- 6.8K Security
- 742 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
