ZyWALL USG 100 Plus and TLS 1.2
Hello!
Is it possible to enable TLS 1.2 on the ZyWALL USG 100 Plus?
I know that it is old device and support closed but maybe exist some variants? (like this for the old USG 300 https://businessforum.zyxel.com/discussion/3477/zywall-usg-300-and-tls-1-2)
Most popular browsers stop supporting TLS 1.0 and 1.1 and use modern browsers for control will be impossible.
Thanks!
Hi @k1601
ZyWALL USG100 Plus does not support TLS1.2.
If TLS1.2 is needed, you can consider USG110 which supports TLS1.2
Here is the information of USG110
https://www.zyxel.com/tw/zh/products_services/Unified-Security-Gateway-USG110-210-310/introduction
Hello!As I see from the post https://community.zyxel.com/en/discussion/4247/zywall-usg-series-v3-30p9-wk48-firmware-released TLS1.2 now supported.
But I have a problem with update my USG-100Plus.
When I try to update firmware from 3.30(AACV.7)ITS-WK28-r72114 to the "USG 100-PLUS 330 AACV v3.30P9 (WK48)" process stopped.
On the console displays:
[Update Filesystem]
Updating Filesystem
[/util/zld_fsextract]
and rotated slash.
At this stage (slash rotated) very long time (one week) without any others actions. I was able to interrupt it only by turning off the power, after which the device does not boot with the message on the console:
FLASH: AMD 16M
BootModule Version: V1.17 | 12/01/2011 05:20:17
DRAM: Size = 256 Mbytes
Kernel Version: V2.6.25.4 | 2016-07-14 09:27:45
ZLD Version: V3.30(AACV.7)ITS-WK28-r72114 | 2016-07-14 10:14:06
Press any key to enter debug mode within 1 seconds.
BM cmd line: console=ttyS0,115200 root=/dev/ram init=zyinit "-r /dev/sda", address: 0x100000
Uncompressing Linux...done.
Start to check file system...
/dev/sda2: 26/17352 files (3.8% non-contiguous), 16993/69296 blocks
/dev/sda3: 152/41120 files (28.9% non-contiguous), 45664/163841 blocks
Done
mount: wrong fs type, bad option, bad superblock on /dev/loop0,
missing codepage or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
Kernel panic - not syncing: Attempted to kill init!
I can restore the device via flashed the database only (firmware restore didn't help). After the restoration the device works normally with the all my old settings.
I tried hardware reset device before upgrade - it didn't affect. What could be the reason and how can I flash the device?
same problem here. The wk48 version was applied and it was stuck, had to recover. Anyone able to apply the firmware?
Hi @shani ,
Greeting Forum, Please kindly try to hardware reset.
Also we recommend that you replace your appliance due to security issues and performance concerns as USG100 has been end of service for a while.
Thank you
Thanks @Zyxel_Kevin, however after reset, it still didn't work, so i put the previous firmware and applied the settings to get back to where i was,
Welcome to ZyWALL USG100-PLUS
Username: admin
Password:
Router> configure[resd] Sending signal to zyshd_wdConfiguration has been restored to system default.
Username:
Terminate All Processes: OK
kill_process_and_umountfs() returns -6
Restarting system.
FLASH: AMD 16MBootModule Version: V1.17 | 12/01/2011 05:20:17
DRAM: Size = 256 MbytesKernel Version: V2.4.27 | 2015-01-08 20:52:20
ZLD Version: V3.30(AACV.7) | 2015-01-14 21:15:46Press any key to enter debug mode within 1 seconds.
.....................BM cmd line: console=ttyS0,115200 root=/dev/ram init=zyinit "-r /dev/sda", address: 0x100000
/dev/sda2: 31/17352 files (0.0% non-contiguous), 61557/69296 blocks
/dev/sda3: 116/41120 files (4.3% non-contiguous), 22984/163841 blocks
DoneINIT: version 2.86 booting
Initializing Debug Account Authentication Seed (DAAS)... done.
Setting the System Clock using the Hardware Clock as reference...System Clock set. Local time: Wed May 24 09:32:23 DGMT 2023
INIT: Entering runlevel: 3
Starting zylog daemon: zylogd zylog starts.
Starting syslog-ng.
Starting ZLD Wrapper Daemon....
Starting uam daemon.
Starting App. Patrol Daemon.
Starting myzyxel daemon.
Starting periodic command scheduler: cron.
Start ZyWALL system daemon....
Check signature package
Got LINK_CHANGE
Port [2] Copper is up --> Group [2] is up
...............................................Applying system configuration file, please wait...
no startup-config.conf file, Applying system-default.conf
Use system default configuration file (system-default.conf)
ZyWALL system is configured successfully with system-default.confWelcome to ZyWALL USG100-PLUS
Username: admin
Password:
Router> FLASH: AMD 16MBootModule Version: V1.17 | 12/01/2011 05:20:17
Enter Debug ModeUSG100-PLUS> atkz –f –l 192.168.1.1
ERROR
ERROR
ERRORUSG100-PLUS> atcd 0
ERRORUSG100-PLUS> atkz -f -l 192.168.1.1
-f -l 192.168.1.1
OKUSG100-PLUS> atgof
Booting...Now booting kernel in FLASH
BM cmd line: console=ttyS0,115200 root=/dev/ram init=zyinit "-f -l 192.168.1.1 -r /dev/sda", address: 0x100000intird start:0000000084136000 size:00000000000781A3
vmlinux start:0000000084006000 size:000000000012FD5C
mount: fs type sysfs not supported by kernelConnect a computer to port 6 and FTP to 192.168.1.1 to upload the new file.
Firmware received ...
DoneBuilding ...
[Update Filesystem]
Updating Code
-/rw/compress.img bad CRC d05c62e9 (should be d6eda5d8)
(may instead be incorrect password) //rw/compress.img bad CRC d05c62e9 (should be d6eda5d8)
(may instead be incorrect password) /rw/compress.img bad CRC d05c62e9 (should be d6eda5d8)
(may instead be incorrect password) \0
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 99 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 924 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 213 Service & License
- 338 News and Release
- 71 Security Advisories
- 21 Education Center
- 2.1K FAQ
- 1K Nebula FAQ
- 445 Security FAQ
- 238 Switch FAQ
- 214 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 142 Service & License FAQ
- 72 About Community
- 62 Security Highlight
