Static routes can´t access to internet
Hi @ewing,
Do the static routes work properly now?
About the NAT problem, you can create the address object with address type "interface IP".
It would be easier for you to configure NAT rule if the IP is changed constantly.
Yes, the 1:1 nat cant be on interface ip, what I did was assign all the public ips to the wan interface, remove it, then made the 1:1 nat rules, I dont know why but doing that the servers know the route wheres the gateway, maybe they thinked the usg310 was in the network, (mac, arp, cache route) I dont know.0
Hi @ewing,
The interface IP can be configured for 1:1 NAT.
Great to know that static route is working properly now on your device.
If you have further questions on NAT, please feel free to let me know.
Maybe I did not explain well, the problem , the additional public ip not working in 1:1 nat only if first assigned to the wan interface, remove it from wan and until then assigned to the server.this method work like 18 days with no problem, until yesterday, I lost connection to the server from the public ip in 1:1 nat, I made the solution explained before and work again but this time only for a few hours, made it again and did not work, reboot the system but did not boot until the third time.0
- 588 USG FLEX H Series
- 477 News and Release
