Log: Maximum sessions per host (1000) was exceeded
verismart
verismart Posts: 2 image  Freshman Member
I receive loads of log messages that say that Maximum sessions per host (1000) was exceeded on a USG 100 device. Source and destination
Can I un select the Enable session limit. Becuse no need funtion firewall with zyxel.
  • CHS
    CHS Posts: 181 image  Master Member
    I suggest upgrading the firmware to the latest version as a first step. After the upgrade, carefully monitor the system to determine if the issue still persists.
  • CHS
  • verismart
    Yes . I already to upgrading the firmware . But still issue.
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,353 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @verismart
    May we know what is the firmware version you are using now? We suggest you can update to the latest version V5.36P2 firmware for further verification. Thanks.
