Still problems with Client VPN connections after Update Firmware 4.73(AAPK.2)
FMGregor
FMGregor Posts: 1 image  Freshman Member
we have still problems with VPN connections after updating our USG1100.
Users are still not able to connect via Software
IPSec_3.8.204.61.32(perpetual). The connection setting is "Remote Access ( server roll )"
Can anyone help ?
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,482
    100 Answers 1000 Comments Friend Collector Ninth Anniversary
    image  Zyxel Employee
    Hi @FMGregor
    To further investigate this issue, would it be possible for you to provide me with a private message containing the HTTPS access session? This will allow me to directly look into the matter.
  • StefanZ
    StefanZ Posts: 203
    First Comment First Answer Friend Collector Third Anniversary
    image  Master Member
    Having a similar issue, where our FLEX200 fails to load up the config after FW updates, then defaults to stock settings. After forcing the load of our backup config, it all works, BUT that one VPN gateway forgot which certificate to use.
