DDNS Update with Public IP for cellular interface don't work bug
PeterUK
edited May 2023 in Security
VPN300 V5.36(ABFC.2)
With a DDNS setup for cellular1 interface there is no update check happening to site check like:
http://ip1.dynupdate.no-ip.com/
Which should check every 5 minutes
However other interfaces for DDNS do check every 5 minutes just not cellular1 interface.
    Ok solved it!
    So I have a routing rule:
    incoming ZyWALL
    service HTTP
    next hop VLAN443
    I have DDNS going out VLAN 443 and ge4 the HTTP check works fine regardless of the above rule but not for the cellular1 so I made this rule above the rule above:
    incoming ZyWALL
    source address 192.168.8.100
    service HTTP
    next hop cellular1
    Now it works
