SecuExtender 1.1.7 + macOS Mojave
URGENT !!!! For the SSL VPN Client version for the new MacOS release !!0
Where is the SSL VPN Client for MacOS Mojave? Why does it take so long?
Hello, I am not able to run this software on my mac because of version, it does not exist for majove. I am waiting for more than one week and still it is not available, this is not fair.0
@Zyxel_Emily, @Zyxel_Stanley,
Can you update us about the release date? It bothers me to wait without knowing any release date.0 -
The 1st Mojave beta was seeded to developers on June 4th... then it was officially released on September 24th. We will get the Zyxel update in late December. I'm shocked !
Thanks anyway.0 -
Thank you, at least we know the date.0
@erts @Alex68 @Ricardo @LucaCo @kyssling @Blabababa @Bernd @Alexander_Alan @Nac6 @philippegervaix
Guys SecuExtender 1.1.5 is compatible with OS Mojave.
1.) If you have brand new OS Mojave or MAC, feel free to download the 1.1.5 version and everything will work
2.) In case you already installed 1.1.7 on your MAC (even on OS High Sierra). Uninstall/remove SecuExtender and use 'find / -name "*zyx*"' under the root user of your MAC, remove everything somehow connected with zyxel, download 1.1.5 and everything will work
Both solutions worked for us (tomorrow will test it even more).
Don't know why support or guys from Zyxel are not mentioning this solution at least as workaround.
Hope it will help at least couple of you. Enjoy!
Hi pista
I tried the workaround immediate after seeing your suggestion. I can install the app(1.1.5) now, however, when trying to launch this app, it show an error message to me. How can I fix it?
Hi @Blabababa
Not sure why, but for me and my colleagues works fine - solution 1 and 2 as well.
I will try today couple more times (and I will let you know), I guess, the most important thing is to remove all files what SecuExtender 1.1.7 created on your MAC (I found them by command 'find / -name "*zyx*"', I was going record by record and carefully removed them [usage of "*zyxel*" could work as well, I just wanted to be sure, that I will find everything somehow connected with Zyxel]).
Will keep you posted.
Pista0
- 434 Beta Program
- 174 Nebula Ideas
- 416 USG FLEX H Series
- 297 Security Ideas
- 43 Wireless Ideas
- 269 Service & License
- 416 News and Release
- 87 Security Advisories
- 4.1K FAQ
- 87 Security Highlight
