Issues with firmware on couple of USG Flex 200 and Zywall 100
Hi.
We are having issues with Flex 200 v 5.32(ABUI.0) and Zywall v 4.71(AAAA.0) !
the VPN service stoped working for the costumer , then wen we tryed to access the firewalls with the gui , they are unresponsive ! after a while we get: wrong Cli command device timeout… then we tryed to access withh ssh and there we are getting unable to connect zySH deamon ! What to do to get a fresh firmware in this stage ?
You need to update the firmware best to unplug from from WAN and reboot
Thanks PeterUK !
Do you think its necessary to boot in debug mode or , just a reebot will do the trick ?
@zpe I suggest you reboot the device first and try again. Please upgrade to v5.36Patch2 which fixes vulnerabilities and VPN connection issues.
If the upgrade fails, please refer to this article.0 -
Thanks , Zyxel_James we will try that !
Hello!
Unfortunately, we're unable to upgrade the ZyWALL 110 device to version 4.73. We're considering downgrading it to version 4.6x. We've been unable to locate the file the downgrade. Could you please assist us in finding it?
Why can't you upgrade? try V4.72 then 4.73
https://support.zyxel.eu/hc/en-us/articles/360013941859-Security-Products-Firmware-Overview-FLEX-ATP-USG-VPN-ZYWALL-
Downgrading has other vulnerabilities.
We acctaully managed to upgrade one firewall , will se if its fully functional in couple of days…
We have a USG 200, its also randomly (after 2 years) showing the same symptoms, after being up for ~ 60 - 90 seconds the router appears to lock up, it cannot be logged into - although it appears to be working correctly for a few hours until it starts totally locking up and dropping WAN to the network.
Is this some kind of attack being aimed at Zyxel Routers?
Performing a factory reset is really going to be problematic and the router does not stay responsive long enough to upgrade the firmware (even when set to automatically do it).
Unplug it from WAN then upgrade
Yes sure but why do you need to do that? Is this some kind of DoS problem?
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
