Mesh compatibility - WX3100-T0
Pbee
Pbee Posts: 39 image  Freshman Member
First Answer First Comment Friend Collector Fourth Anniversary
edited May 2024 in Wireless
I understand that the WX3100-T0 Mesh function usually doesn't work with other brand AP's like Fritzbox for example. Does it work with Zyxel AP's like WAX650S and/or WAX610? We're looking at using wireless Mesh or the wired roaming functions. We prefer the latter of course.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,320 image  Zyxel Employee
    HI @Pbee ,
    Zyxel APs like WAX650S/WAX610 utilize wireless Mesh technology to connect exclusively with other Zyxel APs. Wireless Mesh functionality is not supported between Zyxel APs and WX3100-T0. For information about the Mesh solution available for WX3100-T0, please visit this link.
    When it comes to wireless client roaming between Zyxel APs and WX3100-T0, the following conditions should be met:
    • The SSID and security method must be the same.
    • There should be a 15% to 20% overlapping coverage between the two devices.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    HI @Pbee ,
    Zyxel_Judy
    Untitled Image
