ATP100 - Signature date "Threat Intelligence Machine Learning" out of date
2»
  • QuiteSmart
    QuiteSmart Posts: 68 image  Ally Member
    Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - WLAN
    this seems correct to me.
    I expected that on patch2 besides handling the two quoted CVE there would had been the fix for TIML updates as well.
    Is there a newer weekly firmware whice solves both problems?
    Is the weekly firmware a beta?
    ty
  • jonatan
    jonatan Posts: 200 image  Master Member
    5 Answers First Comment Friend Collector Eighth Anniversary
    edited May 2023
    @aait @QuiteSmart
    This weekly update includes a patch.
    https://support.zyxel.eu/hc/en-us/articles/11616709217810
    This is the latest weekly firmware, including all fixes + CVE fixes.
  • aait
    aait Posts: 14 image  Freshman Member
    it is not possible to release two firmware versions in the same week with different fixes.. that's crazy! Patch 2 released after 23WK21 does not contain TIML fixes...
  • jonatan
    @aait
    The official firmware release and the weekly firmware are different firmware. The weekly has a large number of fixes, but it is tested less time. No one forces you to put it on, you can wait 5.37, expected in July. Perhaps it will fix the error you need with signatures, or maybe not.
    Everything is written here
    https://support.zyxel.eu/hc/en-us/articles/360005438274
  • e_mano_e
    e_mano_e Posts: 116 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    I've got a few ATP100 devices which are now on firmware "V5.36(ABPS.2) / 2023-05-24 05:21:10" and these devices all has out-dated "Threat Intelligence Machine Learning" signatures.
    What's the danger using these out-dated signatures for the next 4 weeks until the next firmware will be released in July?
  • QuiteSmart
    i am in the same situation with the atp100 atp100w, while atp500 got the timl update
