USG110 - USG FLEX 200
Hi @RikHead,
The online converter supports converting the configuration from USG110 to USG FLEX 500 only. You may convert it to USG FLEX 500 first, and manually edit the file to the configuration of USG FLEX 200. Use the tool to compare the file and then edit the file.
Hi @RikHead,
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 482 News and Release
