Creating - not activating - a Bridge Interface breaks DHCP on members
Once the interface join into a ridge interface.
The original interface function will be turn off and acting like a layer 2 port.
No matter the bridge interface is active or not.
Thanks for the clarification.
This should somehow denoted in the interface, since it is different to pretty much any other interfcace part.
Knowing this and reading the manual…
When you create a bridge interface, the Zyxel Device removes the members' entries from the routing
table and adds the bridge interface's entries to the routing table.… confirms it, but it sure could be highlighted a bit.
Especially since this can completely break your network access to the device.
- 588 USG FLEX H Series
- 477 News and Release
