Firmware Upgrade Procedure GS1910-48HP
KenS
KenS Posts: 4  Freshman Member
edited August 2022 in Switch
The release notes with the V2 firmware suggest that the upgrade procedure is to go from 1.00(AABA.0) to 1.00(AABA.2) and then 2.00(AABA.0). Have I understood that you can't go from 1.00(AABA.0) directly to 2.00(AABA.2)?
If that's true where can I download version 1.00(AABA.2) to do the intermediate step?
  • Zyxel_Lucious
    Zyxel_Lucious Posts: 277  Zyxel Employee
    25 Answers First Comment Friend Collector Sixth Anniversary
    Hi @KenS
    Sorry to cause your inconvenience, we'll PM you for the requested 1.00(AABA.2) firmware.
    Zyxel_Lucious
  • KenS
    Thank you - that's arrived. Much appreciated
  • fibrewire
    fibrewire Posts: 1  Freshman Member
    edited August 2019
    I have the same issue for both the GS1910-48HP and the GS1910-24HP. Thank you!
  • imaohw
    imaohw Posts: 124  Ally Member
    First Comment First Answer Friend Collector Seventh Anniversary
    Just go to ftp.zyxel.com, pick the device name from the list of directories, and then select the firmware directory.
    You should see a list of the various firmware versions that you can download for the device.
  • Urs
    Urs Posts: 1
    It is some time ago this was a subject, however I too need the Firmware version 1.00(AABA.2) in order to be able to upgrade our GS1910-48HP. And yes I checked at ftp.zyxel.com and found only newer ones.
     Thanks for helping me in this regard
  • Zyxel_Jason
    Zyxel_Jason Posts: 416  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    Hi @Urs ,
    Welcome to Zyxel community.
    Please refer to the link below for the firmware of GS1910 series.
    GS1910-24
    GS1910-24HP
    GS1910-48
    GS1910-48HP
    For example, GS1910-48HP V1.00(AABA.2)
    Hope it helps.
    Jason
  • TomR
    TomR Posts: 1
    where is now stored firmware for GS1910 48HP ?
    Thank you
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,438  Zyxel Employee
    Hi @TomR,
    Please reference this link to download.
    Zyxel Melen
