Ipsec via main GW stops work, Found old outbound SPI error in debug log
124»
  • alexey
    alexey Posts: 193 image  Master Member
    First Comment Friend Collector Eighth Anniversary
    edited June 2023
    The ipsec don't work with ZW 1000 too, that don't affected to last buffer overflow issue.
    Sand diag info to PM
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Dear @alexey
    We have noticed that the ATP800 is currently running on firmware version 5.36P1WK21. We recommend that you update it to the latest version, V5.36P2. As for the Zywall USG 1000, it is using V3.30(AQV.7)ITS-WK48, which is functioning properly.
    We suggest that you continue collecting syslog information. If the VPN connection gets disconnected, please share the syslog file with us. This will help us identify the possible reason for the disconnection.
    Thank you!
