Update Usg 310 Firmware
I've planned to upgrade an older version Zyxel firmware model USG310 from V4.65(AAPJ.1) version to 4.73(AAPJ.2). . Just load the fw and automatically reload the configuration? or do I have to upgrade to a higher firmware first?I don´t want to reconfigure.
Will I lose my configuration by upgrading?
Thanks.Regards.
Definitely make a config backup first, in case something unexpected happens. If something breaks in the process, you might end up with a damaged configuration. It is entirely up to you.
edit: in theory, the configuration should be kept, but in case something stops working or the upgrade fails, even after a reboot, it is possible that your device or firmware version requires a blank config to upgrade successfully. I don't have experience with your exact model.
Thanks for your reply
But I need to upgrade to Step, example:
4.65---4.70
4.70---4.73
or can I upgrade directly to 4.73?0 -
This question is covered on page 6 in the PDF manual file in every firmware download.
473AAPJ0C0.PDF is the name of the file (the PDF filename ending in "foss" contains only GNU GPL versions).
From page 6, step 3:
3. Recommended upgrade to ZLD4.65 Patch1 or later version first before upgrading to ZLD4.71.
(Please note that this is standard text and possibly copied from the 4.71 firmware package.)
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
