Port SSL VPN
CallSmart
CallSmart Posts: 1 image  Freshman Member
edited April 2021 in Security
Hello, I configured the vpn ssl on a USG 20, but I can not use port 443. Is it possible to change the port for vpn ssl?
thank you
    I don't think you can but you could add that in Ideas
  • Zyxel_Emily
    Hi @CallSmart,
    You can change the service port from 443 to another port.
    Go to Configuration > System > WWW > Service Control.
    For example: 4433
    Remember to add one firewall rule: From WAN to ZyWALL, service: port 4433, allow
    On SecuExtender, enter IP address with the new port.
    SSL VPN is connected.
