USG40w to Flex 100W Wifi Woes following config conversion
I used the online Zyxel converter to upgrade from a USG 40w to a new Flex100w. Everything came over fine except for the wifi SSID. I found a few reports that the way Wifi is handled on the Flex is different from previously on the 40w.
I don't seem to be able to remove any trace of the converted wifi settings on the 100w to re-create a new, working Wifi network using the built-in AP feature.
If it helps, I do have the original SSID after the conversion but when I access it via wifi, I connect to it but I don't acquire an IP address.
Any help greatly appreciated.
Darrin
Hi @elkrust ,
can you send me FLEX100W configuration file in PM for further checking.
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 458 USG FLEX H Series
- 304 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
