ATP 800 half ipsec tunnels don't up after reboot
Dear @alexey
Thanks for reporting this case to us. Regarding the symptom that you mentioned, it should be the same as this discussion. Please continue collecting syslog information. If the VPN connection gets disconnected, please share the syslog file with us. This will help us identify the possible reason for the disconnection. Thanks.
After update ATP800 to P2, all usg1000 tunnels up.
Later on this week try some times reboot device and watch result
Don't up 2 FLEX50W tunnels. Flex on P2 FW too.
In logs error about duplicate ip adress, that problem in this thread
Send new diag and IKE syslog from both devices to PM.
Hi @alexey
We noticed there is a message showing "2023 zw_holding src="10.0.1.254:500" dst="10.0.1.64:500" msg="IKE SA [vpn_dis_30km_vti_nova_ike2] is disconnected" note="IKE_LOG" user="unknown" devID="d8ece5c4598f" cat="IKE"", it could be the possible reason why the VPN is disconnected, please provide USG FLEX50W and ATP800 remote links to us for further checking. Thanks.
- 238 Nebula Ideas
- 6.8K Security
- 753 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
