SSL secuextender disconnect upon connection
I thought there might be a bad driver.
I removed all the Intel Killer driver package and the Zyxel software. I rebooted and only used the native Windows Wi-Fi drivers along with the Secuextender. This produced the same result. The connection disconnect within 3-5 seconds of the connection before I can authorize the connection via 2FA.
I then reinstalled all the Killer drivers and tested again, the result was the same disconnection. I can however still connect via L2TP.
Regards,
Alan
Can you disable 2FA?
@Alanl I would like to check on your Windows 11 PC. I've contact you throught private message, please check your inbox, thank you.
- 441 Beta Program
- 294 Service & License
- 461 News and Release
