PPPOE nat
Hi, I recently encoutered problem with new customers setup.
There is VDSL line to router bridged to Zywall 110.
Zywall is taking pppoe on wan port and transalte to lan network.
Only I am unable to route incomming data frou outside network.
Goal is to route a service (port 5000) to internal address on lan 10.0.0.x to port 443
NAT is set upped as it should be WAN - specified IP and port to port.
After dificulties i disabled policy routers (firewall) without any improvement.
Do i have to setup any other routing?
VDSL modem is comtrend provided by ISP and is bridged without any other setup to Zywall.
Do you have any ideas what can be wrong?
i am able to connect to zywall remotely - that is only service that is working as it should and confirm it should be all working.
Hello Degard66,
As your description, I just want to confirm something about this case.
Firstly,
Is your topology as below pircture? is any SBG on this scenario?
Secondly,
Do you mean the WanIP with Port 5000 to internal 10.0.0.x:443 not work?
Charlie
I have exactly the same problem. Has it been solved?
Hi @redPlant3d,
Could you describe what the issue happened on your device? Is NAT not working when the wan interface is wan_pppoe?
For my GraylogServer I use this on my FLEX50:
Settings > Network > NAT
- Class: Virtual Server
- Incoming: WAN (in your case you will have to use use WAN_PPP)
- Source: Any (narrow this down for only certain clients)
- External IP: Address-Object with my WAN-Interface-IP
- Port-Mapping-Type: Service-Group Object (I need several ports)
- External Service: The same Service-Group Object
- NAT-Loopback: ON
- 435 Beta Program
- 176 Nebula Ideas
- 119 Nebula Status and Incidents
- 430 USG FLEX H Series
- 299 Security Ideas
- 79 Switch Ideas
- 276 Service & License
- 427 News and Release
- 89 Security Highlight
